shift+command+r are not working
  • April 3, 2025
  • 4 replies
  • 358 views
Subhankar Sarkar
There is no paste and replace option on the menu after I copy the object and when I use command+shift+R, it turns into rename action. Is there anyone know how to fix it?
  • April 10, 2025
Hi ​@Subhankar Sarkar
Thanks for reaching out. Could you try reloading your tabs and restarting Figma to see if that resolves the issue? I've tested it on my end, and everything appears to be working normally in both the browser and the desktop app.
If the issue persists, could you please share some screenshots or a screen recording so I can try to reproduce the problem?
Thanks!
Toku
Ponomarev Denis
Cmd + Shift + Alt + V
Andrei Cercel
  • September 29, 2025
It happened to me as well. Can be related to upgrading to Tahoe 26 (Mac OS)?
I’m on M4Pro
The Denis command worked, but…. too many fingers to use :)))
Andrei Cercel
I’m on M4Pro
I think I found the issue, at least on my side.
I check all the things, I added a new shortcut for in the Settings/ Keyboard on my Mac. But I discovered that I have an app running in background (Be Focused) and when I pressed shift+cm+r the timer was activated :)))
Now it is working well, thank you
