Cannot change text font-weight inside instances
  • March 5, 2024
  • 5 replies
  • 978 views
Julia_Mnizhek
Hey there, lovely community!
I’ve noticed something quite frustrating since the recent Figma updates, and I’m wondering if anyone else has encountered it too.
I seem to be unable to change the font-weight for text inside instances. It always sets to the one that other text has. Changing text font-weight is only working for text that’s not within a component.
Mar-05-2024 18-48-41
If anyone else is experiencing this issue, I’d love to hear how you’re managing or if you’ve found any workarounds.
If there is a similar issue somewhere, pardon me. I haven’t found it yet.
Thanks a bunch!
mo_hamwi
  • Active Member
  • March 6, 2024
Works fine for me 🤷
Julia_Mnizhek
  • March 13, 2024
Hmm, it seems that for certain fonts, if the text is linked to the text property in the component, it will have this behavior.
Kacee_Carter
I’m having the same issue with not being able to update font weight within in instance. One thing I did realize is you can use key board shortcuts for bold, underline, etc and it will override but Figma really needs to investigate this one.
r_sh
  • Active Member
  • August 2, 2024
Same-- we can only make text inside of an Instance bold, etc, if using Keyboard shortcuts. It does NOT stay as an override if the changes are made through the Properties panel
  • August 6, 2024
Hey All, thanks for flagging this and sorry for the trouble!
This is a bug, and it’s already under investigation. Keep in mind that text style overrides currently do not include intermediate font weights (Extra bold, Semi bold, etc.) :
This is likely going to take some time to be resolved as it requires attention from a number of different teams. We apologize for the ongoing disruption it’s been causing!
