Idea: Color override properties
  • January 24, 2024
  • 117 views
Hi! Please let me know if something like this is already available or if any of you found a clever hack:
My use case: I have a list item where designers can change the icon color into a limited set of other colors to fit their specific use-case.
Just as we can create instance swap, boolean and text properties, I would love to be able to set a property on the color overrides where I can select prefered (or even better - limit) the colors the designers can pick.
My current solution is to duplicate all component variants and only change the icon. This however makes the component huge.
  • 2317 replies
  • January 24, 2024
Hi there,
Thanks for reaching out. I might be misunderstanding, but could this be a potential solution: https://www.youtube.com/watch?v=vCnB8bAEFl4? It seems like it might not be straightforward. Iโ€™d like to confirm if this aligns with what youโ€™re thinking.
Toku
