Figma plugin to merge color styles with the same name and/or merging styles from a list
  • September 16, 2021
  • 11 replies
  • 1263 views
Nader
Hi, is there a Figma plugin allowing to merge color styles with the same name and/or merging styles from a list like the Sketch plugin “Merge Duplicates”? It allows you to select which styles you want to merge (from the whole list of styles within the file) and merge them, even if they have different names. The style you decided to keep applied to all layers (and overrides) using the discarded styles, and the discarded styles removed.
Antoine2
Hi,
Is there a way (native or plugin) to merge styles (like two colors styles)?
The only way I see is using Selection colors: unlink the style I want to merge and then apply the style to the unstyled color. But it doesn’t work if other elements in my selection carry that color.
Thanks!
  • July 17, 2023
  • August 22, 2023
+1 also need this
  • August 23, 2023
Yes, much needed. I just switched from Sketch to Figma and am missing the Merge Duplicates plugin a lot. I can’t find any equivalents in the Figma Community.
Danielle_Timcke
+1 also need this
Teddy
  • November 7, 2023
+1 for this need!
Sascha_Koeth
+1 definitly a must have!
Santiago_Eastman
+1 definitely!
FilipaGo
  • May 23, 2024
+1! We really need an option to merge styles.
Jacob_Setoh
+1 just encountered this problem as well, we need merging styles options
Dennis_N
  • July 16, 2024
Not sure if a plugin could do that but here is the link to the native feature request: Merge multiple text styles into one
