Allow break lines in string variables
  • July 3, 2023
  • 21 replies
  • 6626 views
Daniel_Marcos
I’m trying to localize an app using the new variables feature but it looks like I can’t add break lines to the string.
For titles, especially in some languages like Japanese where there are no spaces, it is totally necessary.
Is this planned for the near future?
David_Clayton
I would also love this feature, I’m trying to error messages in multiple languages and we really need line breaks!
chanwen
  • August 14, 2023
Agree, I would love this feature, too. This is critical for marketing-related materials in character-based languages such as Chinese and Japanese. Otherwise, some key phrases might be wrapped accidentally into two lines and cause confusion when reading.
Borys_Sviet
@Daniel_Marcos
There is a workaround this issue. Before pasting text into variable input, put it aside as plain text, make a break line with shift + enter shortcut, then copy and paste this text to the variable input
Daniel_Marcos
  • August 28, 2023
Thank you Borys for the tip! It works great!!
  • November 26, 2023
rahend
  • Active Member
  • March 6, 2024
Continuing the discussion from Allow break lines in string variables:
The approach from @Borys_Sviet did not cover the paragraph spacing. What I’m trying is to handle paragraphs in multi-language using variables, so sometimes I need to break lines and add a paragraph space to them.
Jason_Thompson
Doing two line breaks (eg; old skool HTML where we did
) seems to work and give a simulated paragraph break. You’d do SHIFT-Enter twice.
rahend
  • Active Member
  • April 18, 2024
Yes indeed @Jason_Thompson, but it doesn’t work with paragraph spacing properties. doesn’t it?
Brian_Nail1
This workaround didn’t work for me. It ended up looking like this and failing to insert the line breaks.
Benjamin18
  • May 20, 2024
Inserting a UNICODE paragraph Separator (U+2029) into the variable string works here:
  • Figma desktop app: 116.15.15
  • macOS 14.5
tcldr
  • May 23, 2024
Apple’s IDE, Xcode, handles this well in its Strings catalogs using an alt-return. A multiline browser would be a nice touch too.
The interface looks like this:
S_e_b_a_s_t_i_a_n
This works, but the result is different to a real paragraph spacing.
And I hate Figma for stupid work arounds like this 🤯
rahend
  • Active Member
  • June 25, 2024
Indeed, we need a real thing than an approach look-a-like
Sergey_Tomashevsky
Ioana_Ionescu
  • March 17, 2025
@Daniel_Marcos
This didn’t work for me. Does it still work for you? Do you have another solution? Thanks!
Jeremias_Santos
@Ioana_Ionescu Are you sure? I’ve just tested the aforementioned method and it worked! Just paste the desired text (with your break lines created) to the input, just like you would with any other local variable value.
Ioana_Ionescu
  • April 8, 2025
@Jeremias_Santos
Yes, I just tried it again and it doesn’t work :( I pasted the text with the break lines from Notepad and it’s still just one line of text. I used a unicode - Line Separator (U+2028): [‌
] I pasted the value between the brackets where I wanted my break line to be. That’s the only way I could make it work.
Jeremias_Santos
@Ioana_Ionescu Have you tried creating the break lines in Figma with the Text tool? Copy the text from there, not Notepad, and it should work.
Ioana_Ionescu
  • April 8, 2025
@Jeremias_Santos Thanks! Looks like it worked this time. I tried it when I first came across this issue and at the time it didn't work.
Emile_S
  • July 4, 2025
Using the text tool in figma to add multiple line breaks and pasting into variables didn’t work (Figma on pc).
Shift+enter in variables editor doesn’t work.
The only thing that worked was copying and pasting - Line Separator (U+2028): [‌
] I From ​@Ioana_Ionescu  post above for which I thank greatly.
This really shouldn’t be an issue. I really hope that now UI3 is out, they can focus on doing something actually worth while, like making variables interface a bit more user friendly.
Joachim_Shotter
