Copy-paste component properties
  • May 9, 2024
  • 648 views
Sammy_Guergachi
If you have many instances of a component, and you set props a certain way on the 1st instance, there is no way to quickly apply the same prop config to all other instances.
  • “Paste to replace” does not work.
  • “Paste properties” only pastes the visual properties (color, border…)
  • In some cases (e.g. slotting), duplicating the 1st instance many times is not possible.
→ A “Copy/Paste component properties” item in the context menu would be very useful, and show an error tooltip (like for Paste to replace) if the target component is not the same as the destination one.
  • Figmate
  • May 13, 2024
Hi @Sammy_Guergachi, Thank you for sharing your thoughts about copying and pasting properties.
I’m not sure if I understand your thoughts completely, but I found a similar request that might align with what you’re describing: Copy/paste the overrides of any instance
Please take a moment to check it out!
If it sounds good to you, I can merge your topic with the one above to consolidate all related feedback in one place. Just let us know if you agree with this approach.
If I’ve misunderstood your idea, please don’t hesitate to provide more details! We’d like to know more about your idea.
Thanks again for your valuable input,
Fabian Schneider
I would also find this feature very useful! Current plug-in solutions don’t work properly.
