Copy/paste the overrides of any instance
It would be great to be able to copy the overrides of any instance and then paste it into any other instance of the same component. Just like with copy/paste of properties!
For example, I have lost of different layers turned off/turned on in a certain instance, and I need to copy that around many other ones!
To copy and paste overrides, you can use this plugin: Figma - Maximum Override | Compare objects to see what's different, then copy and paste the changes. Compare instances to th...
It doesn’t work with deeply nested instances.
