Adding auto-layout should keep Fill-resizing in children
  • May 18, 2022
  • 7 replies
  • 1414 views
Maty
If i select multiple layers (inside an Auto-layout) with width property set to “Fill”, and then add an Auto-layout, all the layers inside the new frame will have their sizes set to “Fixed”.
I have to manually set the layers back to “Fill” every single time i want to enclose layers in an Auto-layout. This is something i run into every few minutes while working.
This is because the new AL layer is automatically set to “Hug”, therefore the children must lose “Fill” property
Wouldn’t it be logical, if i apply Auto-layout to layers that are already set to horizontal “Fill”, that the newly created AL layer is also set to horizontal “Fill”, leaving the children to “Fill”?
Gareth
  • Active Member
  • May 18, 2022
agreed, this would save me years and several hundred clicks every time i change the stack alignment from horizontal to vertical…!
  • August 16, 2022
Ben_Dansby
  • April 12, 2023
If I create a frame within a frame with auto-layout, please adopt those auto-layout properties automatically in the new frame. Currently, not only do I have to set the new frame, I also have to adjust its children to not use fixed sizing. Very tedious and time-wasting.
Same as here: Adding auto-layout should keep Fill-resizing in children
Maty
  • April 12, 2023
Yep, this annoys me on daily basis, every few minutes i have to re enable ‘fit to parent’ on many layers… This is super tedious
  • April 13, 2023
Hi @Ben_Dansby , thank you for your feedback.
I re-opened the previous topic Adding auto-layout should keep Fill-resizing in children and merged these two topics to gather all your feedback. Thank you!
Maty
  • August 18, 2023
This has been silently implemented!! HUGE improvement!
Thanks
Tsvetozar_Georgiev
BAD “improvement”. For example, you’re getting icon only button from the iOS UI kit (which is set to fixed by default) and make a few in auto-layout group and then guess what - all of them get messed…
This is very annoying. At least make the “Suggest Layout” option to work the old ways and not convert automatically to Fill.
