Hello,
currently using the Export widget is very cumbersome.
You have to click on a project layer, expand the Export widget, select a file size (1x, 2x, …), select a file format, expand the preview and save.
This has to be repeated with EVERY attempt to save!
When will you change this so that the widget expansion, selected format, file size and preview display is remembered!
This looks more like a suggestion so you can move it to #product-ideas and change the title to something that describes your suggestion. People with the similar issue would be able to vote for this to be implemented.
Yeah, it should be like just Fill/Stroke/Effect
A simple rule of UX: minimize the amount of work a user must do to perform an action.
Having to change the resolution multiplier every single time I try to export? Really irritating.
It’s been quiet for two years…
As a developer, I need this feature badly, and often have tons of images to export.
+1 on this. Any updates regarding this feature request?
