Negative padding (workaround)
  • November 29, 2023
  • 20 replies
  • 6790 views
Hi everyone,
As you know, being able to add negative padding is a must when creating design systems. However Figma only allow negative values in the inner-spacing between elements in auto-layout.
We found a workaround and thought it would be useful to share it with the community.
If you define a local variable, type number, and add a negative value (e.g. -4px), you can then apply this variable to the auto-layout padding and it will work.
In summary: use local variables to define negative values and apply such variable to the padding.
nestroompast
Assuming negative margin is already available but developers just didn’t put the feature out for some reason
  • February 15, 2024
Thanks for the feedback and for providing the workaround @Rafael-Atlanttico!
We’ll pass this onto our team for consideration.
Daniel_Cullinan
Curious to know what you mean by this, as negative padding is not possible in CSS?
Anna_Willoughby1
well an example i’m needing it for is trying to create a prototype of a scrollable list that, when you complete something on the list and return, focuses on the next thing on the list - scrolling the completed items out of view. i don’t know any way to do this in Figma other than setting negative padding on the container
Daniel_Cullinan
I would do that by creating a frame without auto layout, turn on vertical scroll behaviour, and then position the scrollable list inside that with a negative Y (vertical) position:
Figma – 20 Feb 24
In CSS, ’padding’ refers specifically to the space between an element’s border and it’s content: CSS Box Model
Justin_Reid
Just what I was looking for. Really helpful, thanks!
jo1
  • March 12, 2024
Screenshot 2024-03-13 at 09.33.06
Can Figma please allow negative spacing on horizontal when doing auto layout?
Very useful for setting up tables etc.
Thanks
  • Figmate
  • March 15, 2024
Hi @jo1, Thanks for sharing your thoughts about horizontal padding! I understand how handy it allows input negative numbers for you.
I found the other community member asking for something similar here. So I merged your post to have all the feedback in one place!
Feel free to Vote up top!
You’re right, I meant negative margin, but in Figma’s auto layout case it’s padding as you can’t manipulate margins in auto layout.
Hence the workaround using variables for negative values and applying that to auto layout paddings. Works like a treat.
Bump for feature
Drugge_Niklas_SOK
We really need negative margin. Its such basic feature for CSS and recreating it in Figma is such a hassle at the moment. @dvaliao would you happen to have any updates on this?
  • March 26, 2024
Hey @Drugge_Niklas_SOK, thanks for the additional feedback!
I can confirm that this is on our team’s radar, but we don’t have an exact timeline to provide yet. Feel free to keep an eye out on our future releases!
Emmie_Paivarinta
I really want this too. Because it works with variables makes it likely it’s just an arbitrary validation for the input.
I checked if I could get around it using the plugin API, however there you can’t set negative margins, I got this error in the console:
Error: in set_paddingTop: Expected “paddingTop” to have value >= 0
Katie_Rowell
Again, pushing for allowing negative margins. Really frustrating our dev. system accounts for negative margins and we can’t mimic that in Figma.
John_Likes_To_Edit
bump for feature as well !
Negative margins are perfect for certain one-off or infrequent scenarios such as needing a separator to reach the edges of its parent container that has padding applied. To achieve this currently without the variable hack, you’d have to create a group soup and apply padding to non-separator layers multiple times.
GG_Yap
  • September 20, 2024
green is padding width
example i use absolute position to do that image on outside, how you all do it?
hope the padding can use negative padding
Maria_Soliman
  • February 3, 2025
I would actually even argue we need margins in general. Allow the full box model. Margin, border, padding. Would make handoff so much easier!
Sensible1
  • April 30, 2025
It’s a little frustrating googling a question of “how do I emulate basic CSS features in Figma” only to find a year-old forum post where people have been asking for the feature to be added for months and months.
Anyways, yes, adding to the pile of of people asking Figma to support basic layout concepts like negative margins.
tomiwao
  • August 1, 2025
Worked for me. Thank you!
