Turn variant into standalone component and retain instance connect
  • September 7, 2022
  • 668 views
Kelly_N
I’m cleaning up a design system in need of proper cleaning. The system has been in use for over a year, so less detached/missing instances I can manage, the better.
One component I’m tidying up (a list row item) has a variant that’s completely different from all the others. It’s using similar content to all the other variants, but its usage in the design, and right-side content, are far removed from how other variants are used.
Is it possible to move that variant outside of the component it’s in right now, turn it into a standalone component, but retain its connection to all the existing instances of it?
Best answer by tank666
  1. Drag your Variant outside the purple border of the Component Set. This will make it a separate component.
  2. Publish design system changes.
  3. Accept the update in the file where the design system is used.
Instances should now refer to that separate component, not to a missing variant in the component set.
You can try this on a test file to see if it’s correct.
  • 4873 replies
  • September 7, 2022
Kelly_N
  • 4 replies
  • September 7, 2022
Wow… I can’t believe I haven’t thought of that. 🤦‍♀️
Thank you, I’ve learned something new and super cool, and you’ve sped up my cleaning process!! 🙏
  • October 7, 2022
