This interaction will not be triggered as interactions on instances are triggered before inherited internal interactions
Chris_Seymour
I’m getting a warning message appear on all of my components with interactions. I’m able to re-produce it by creating a basic text component with 2 variants and a hover state change. Can someone share any insight into why this is happening? Screenshot and message below.
“The interaction will not be triggered as interactions on instances are triggered before inherited internal interactions”
Best answer by Celine_
Hey Simon, thanks for details! This looks like a long standing bug that our engineering team is aware. It would be great if you can reach out to the support team with a copy of your file, so we can double check and investigate it further by filling a form here: https://help.figma.com/hc/en-us/requests/new.
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look. Thank you!
gregmodor
  • January 12, 2024
I have a component that has 6 options.
Between the variants I added animation “After delay - 1ms, Smart animate”.
When I try to add the first option to the main frame to test the animation, I get an error (the one in the title) and the animation doesn’t work.
When I tried to add another component with the “While hovering” animation, it got the same error, but the hovering animation worked.
I tried reloading the application, deleting the project and creating a new one. But nothing helped.
Perhaps someone knows how to fix it?
Frederic_Fornini
Hello, i have the same issue here, prototypes that used to be working perfectly, don’t work anymore because of this change.
Celine_
  • 3751 replies
  • January 12, 2024
Hi everyone!
This type of error message is generally shown when Figma detects that there is a conflict between the interactions you have set on your main component variants and the interactions set directly on your component instances. Figma will prioritize the interaction on the instance over the interaction set on your component variant.
In order to investigate further, we would like our technical team to have a deeper look at it. Please reach directly to us with a copy of your file by filling out a form here: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look. And please, also add your screenshot/recording video so we can try to replicate it. Thank you!
Frederic_Fornini
To develop a bit more on the topic.
Here’s the link within the component, everything looks fine in term of interaction.
As soon as i turn it into an instance i have this warning.
It’s hard to wrap my head around this, has i don’t see any other way to change a button state (beside using variables).
j.willetts
I’m having this same issue today - I’m not applying any new interactions to the instance, just expecting the component to do the interactions set in the master component…
Frederic_Fornini
@Celine_Figma i can’t share the actual file i’m having problems with at the moment (client NDA). I’ll see if i can cook an example.
Anyway as stated before, inside the component everything is fine, as soon as it becomes an instance, the warning appears. Even when it’s a standalone element not included in any artboard. (which is the example above with the screen capture.)
  • January 12, 2024
This is happening to me too today.
Mike24
  • January 12, 2024
Also getting this error for the first time.
Sam_Coney
I’ve also been getting this message for the first time today and the context for it seems false.
New bug in the software maybe?
@Figma - Can this be raised as a ticket to look into?
ksn
  • 1804 replies
  • January 12, 2024
Hey all! Can you all take a look to see if this is still a problem? Our engineering team pushed out a fix, and this shouldn’t be happening anymore.
Frederic_Fornini
@ksn i don’t see the warning anymore, that’s a first.
It seems to be working, thanx for the quick fix !
I still have a problem on one of my components but i’ll investigate.
ksn
  • 1804 replies
  • January 12, 2024
Great! Thank you – yeah feel free to drop your findings here when you have a min 😁
bigfudge
  • 11 replies
  • January 15, 2024
Still experience this on a simple Checkbox interaction. I didn’t create it myself, it’s a component in the SAP design system file, but I don’t see why this shouldn’t work bc the component isn’t created any other way I would create it.
It’s a nested checkbox component in a page template. I don’t see any reason why this shouldn’t work. If I detach the page template component I can set the interaction. ¯_(ツ)_/¯
Celine_
  • 3751 replies
  • January 15, 2024
Hi @bigfudge! This seems odd, thanks for flagging this. Would you mind reaching out directly to the support team with a copy of your file here: https://help.figma.com/hc/en-us/requests/new
This will help us to invesigate further and try to replicate the issue. Thank you!
bigfudge
  • 11 replies
  • January 15, 2024
Hi @Celine_Figma thx for the prompt reply. As it’s an open lib (SAP Fiori) you first have to downoad and import for yourself, I don’t know if my file helps as it is bound to a published lib of said design system within my organization.
Celine_
  • 3751 replies
  • January 15, 2024
The best option will be to share the affected file directly to the support team. You can send directly a link to the file, and share it with support-share@figma.com by inviting them directly as an editor so they can take a closer look. (this won’t affect your billing at all).
Be sure also to use your Figma account email, and a quick screenshot/video recording, this will help us to better visualise your issue. Thank you
bigfudge
  • 11 replies
  • January 15, 2024
Ok, send it out. Thx
I have also this alerts showing in my buttons hover interaction, but when in Prototype mode it works perfectly fine. I guess that, as my button has a instance property of “click”, while the hover property is from the parent, Figma is trying to say me that the hover won’t work because first is the instance interaction, and as this one is a click interaction, the “hover” won’t show up.
To be honest, this is not a problem for me as I said earlier, because my component still works. But obviously, it is a issue because if this is the case, then Figma is showing me false information in the UI, wich can be a problem later on.
Celine_
  • 3751 replies
  • January 16, 2024
Hey everyone,
Thank you for your patience while our engineers worked on resolving the issue you reported. We are pleased to inform you that the fix has been successfully released!
Please refresh Figma to ensure that you are using the fixed version. If you continue to experience the issue, please let us know by reaching out directly to the support team with a copy of your file so we can investigate further here: https://help.figma.com/hc/en-us/requests/new
We apologize for any inconvenience this issue may have caused you. Thank you!
bigfudge
  • 11 replies
  • January 17, 2024
The Warning is gone now, thanks for the quick turnaround here.
I don’t know if it’s another issue that’s addressed in a different context, but now The option to choose from when adding an interaction “on klick change to…” just shows the Properties for the surrounding component instance, not the component I need to change properties for. In this case a datepicker component inside a page component.
See Screenshot of actual option available:
and options for properties expected:
Any idea @Celine_Figma
Celine_
  • 3751 replies
  • January 17, 2024
Hi there! Can you clarify what you intend to do? Do you mean that you try to add an interaction directly in the datepicker component?
Not sure if it is bug without investigating with a copy of the file to check your component in details, (but this is not related to the issue within thread). As said, I suggest you to reach out directly the support team with a copy of your file so we can try to replicate in our end here: https://help.figma.com/hc/en-us/requests/new Thank you!
bigfudge
  • 11 replies
  • January 17, 2024
Celine_
  • 3751 replies
  • January 22, 2024
Aurelien_Aries
Any update on that bug ?
Thao_Le1
  • 5 replies
  • July 16, 2024
Hi everyone, I still have this issue. Any updated on that bug?
