Hello there, I seem to be having a problem switching between variants created from a component set. I’m trying to switch between left and right (Icons) variants and no matter the variant I choose (default or variant 2), the icons remain the same rather of changing.
Some elements in your Right Slider are rotated 180° so when you swap variants they reset to 0°. This has the net effect of making them look identical when swapping.
To fix, remove all those 180° rotations so that everything in the Right Slider is set to 0°.
