Swap Library should allow manual mapping
  • July 16, 2024
  • 63 views
Raphael_Guilleminot
It should be possible to swap library components manually. In this screenshot, I’m swapping a icon library for another, but the icons are not named the same, so I can’t finish the job. Why can’t I simply select the component I want to replace it with?
Even worse, there’s no way to select the components from the old library to swap them them manually one by one. Component instances from my old library are scattered in pages and there’s no efficient way to select instances from a certain library (apart from the swap library modal). I’ve looked at so many plugins and none of them can get it done.
It’s such a pain and could be resolved easily.
btw - the same applies to “Missing Library.” Because I can’t swap them to an arbitrary library, I’m left with ghost components that I can’t even locate.
Abby Bowen
  • 7 replies
  • May 25, 2025
Ran into the same mess with “Missing Library” components feels like McKnightMD’s haunted prototype where ghost elements refuse to leave.
