Seeing a stroke in design even when the storke value is Zero
  • August 24, 2023
  • 11 replies
  • 662 views
Fayas
Wanted to report a weird bug in Figma. Even when the stroke value is zero, I can see a stroke in the design. It disappears when I increase the stroke value and again make it to zero.
Best answer by Josh
Hey all this should now be fixed! Thanks again for reporting this! 😊
Fayas
  • August 24, 2023
Fayas
  • August 24, 2023
Delia_Villadsen
I am experiencing the same thing since early morning
Guillaume_Pons
Same here…
j.willetts
  • August 24, 2023
Getting the same here…
Rob_Tranter
  • August 24, 2023
Having the same issue. There is now a stroke around any element where the value is zero.
Katia_Dryazgina
Same problem across all the files
Paul_K
  • August 24, 2023
The same. Hope it’s just a bug and Figma team will resolve it as soon as possible, as qa teams, marketing, front-end guys all dependent on correct Figma files and I’m absolutely not sure that I should manually fix it for hundreds of files
Josh
  • Former Community Manager
  • August 24, 2023
Hey all, are any of you able to share a file where you’re seeing this happen?
If you could add support-share@figma.com as an editor and link it here or send a DM that’d be great!
Paul_K
  • August 24, 2023
Hey Josh, check DM
Josh
  • August 24, 2023
