Is it possible to prototype the slider interaction from figma forums? There’s a relation between the red and green container, which is a great interaction. As far as I understand, you can’t have things relating to each other in prototypes, is that right?
It’s a bit of a hacky solution, but you can have two frames: one with the slider knob at the top and the forum showing the top comments, and another with the slider knob at the bottom and the forum showing the bottom comments. Have a “on drag” animation for the slider with smart animation transition from frame 1 to frame 2. You won’t be able to scroll to a specific point of the forum based on the slider, but this will at least show what the interaction would look like.
