PDF export - is anyone else having these issues?
When exporting a Flow to PDF (By making a frame around the frames I want to export and setting the Export settings for that Frame to PDF) it will sometimes fail silently.
And with fail silently I mean that the save dialog doesn’t appear. Just nothing/nada/zilch.
After some experimenting it seems to be an issue with the “physical” size of the Frame I want to export. (It breaks somewhere around the width of 7500 pixels)
Is this a known issue or should I attempt to submit a bug report?
Definitely submit the report to Figma support team via the bug report form.
Will do, thank you.
