D_S
July 2, 2021
Linking CSS to UI.HTML
  • July 2, 2021
  • 10 replies
  • 6996 views
How do I import CSS to my UI.HTML file? I’ve been trying forever but unfortunately with no luck.
ui.css is linked in my project folder, not under any folders.
Here’s what I currently have in my ui.html file:
<link rel="stylesheet" href="ui.css">
Any help is appreciated. Thank you so much!! <3
When I try the same code in the browser, it links and the elements change but, when I open my Figma Plugin’s UI window, there’s no luck.
Best answer by Gleb
The plugin only loads what’s listed in the manifest.json, ignoring all other files. Since it only allows you to specify HTML for UI and JS for backend, you have three options here:
  1. Write CSS and JS inside of the HTML file so you don’t have to load them from other files.
  2. Host and load CSS and JS from the web. Not every hosting would work due to CORS and the plugin having origin set to null. This isn’t a very common way I think.
  3. Use a bundler to inline all files you want into HTML. This is good for larger plugins where writing CSS and JS directly inside of the HTML file would be difficult. You can use Rollup, Webpack, esbuild and anything else you like.
GlebAnswer
Power Member
July 2, 2021
D_S
D_SAuthor
July 2, 2021
Worked like a charm! Thanks so much. Have an excellent weekend!
Bruno_Sastre
@D_S Can you share your solution, please? Having the same issue here…
August 24, 2023
did you find the solution? extrnal css is not working at all. No imports no npm package is working
Nigel_Morford
May 9, 2024
In the manifest there is a “allowedDomains” portion. If you add the cdn link to css sheet you can use external css in the plugins.
June 6, 2024
Does it work for you guys? I tried to put the CSS code inside the HTML file as inline CSS, but only tag-targeting stylings work (e.g. a, html, body, etc.). All class-based stylings (e.g. .text-center, .justify-start, etc.) are not working at all.
Laurence_Penney
October 10, 2024
This worked for me. I’m using parcel as my bundler.
<style>@import "./ui.css";</style>
Laurence_Penney
October 10, 2024
And this for the JS:
<script type="module"> import "./ui.js"; </script>
MoNe
this is how my webpack file looks like. It’s working :)
const path = require('path');
const HtmlWebpackPlugin = require('html-webpack-plugin');
const HtmlInlineScriptPlugin = require('html-inline-script-webpack-plugin');
const MiniCssExtractPlugin = require('mini-css-extract-plugin');
const HTMLInlineCSSWebpackPlugin = require('html-inline-css-webpack-plugin').default;
module.exports = (env, argv) => ({
mode: argv.mode === 'production' ? 'production' : 'development',
// This is necessary because Figma's 'eval' works differently than normal eval
devtool: argv.mode === 'production' ? false : 'inline-source-map',
entry: {
code: './src/code.ts', // This is the entry point for our plugin code.
ui: './src/ui/ui.js', // Entry point for plugin main code
module: {
rules: [
// Converts TypeScript code to JavaScript
test: /\.tsx?$/,
use: 'ts-loader',
exclude: /node_modules/,
test: /\.css$/,
use: [
MiniCssExtractPlugin.loader,
'css-loader',
// Webpack tries these extensions for you if you omit the extension like "import './file'"
resolve: {
extensions: ['.ts', '.js'],
output: {
filename: '[name].js',
path: path.resolve(__dirname, 'dist'),
plugins: [
new HtmlWebpackPlugin({
filename: 'ui.html',
template: './src/ui/ui.html',
chunks: ['ui'], // Include only the 'ui' chunk (from ui.js)
inject: 'body', // Inject JavaScript into the body
new HtmlInlineScriptPlugin({
scriptMatchPattern: [/ui\.js$/], // Inline only the ui.js script
new MiniCssExtractPlugin({
filename: 'styles.css', // Outputs styles.css temporarily
new HTMLInlineCSSWebpackPlugin({
styleTagFactory({ style }) {
return `<style>${style}</style>`;
don’t forget to update your manifest.json to point the ui to dist/ui.html
  "ui": "dist/ui.html",
Yoriiis
As shown above, with webpack, the html-inline-script-webpack plugin works well even though it doesn't seem to be maintained. I've used it and it does the job.
https://www.npmjs.com/package/html-inline-script-webpack-plugin
