Image container and radius that disappear when image is uploaded
Hey team,
As part of a design system, I am working on an image container component. Goal is for designers to update the image within the container and then, they can easily pick the ratio of the container they would like to use.
The container has a 4px radius. Nevertheless, the radius disappear when I past an image within the container (opt. - cmd- C / opt. - cmd- V).
Is there a way to keep the radius?
Thank you!
ScreenRecording2024-05-23at11.23.49-ezgif.com-video-to-gif-converter
HI there,
Thanks for the post. It seems it’s working fine on my end like this:
Here are some actions you can take to improve performance and the resolve most issues, so can you try these?
  • Close any Figma tabs you’re not using
  • Browser: Force-quit and open Figma in a new browser window.
  • Desktop App: Force-quit the Figma Desktop app and restart it.
  • Clear desktop app cache →
If the problem persists, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it/
Hey Toku,
Thanks for your help.
I did all the recommended actions, but it didn’t seem to fix the problem.
Here’s the page, if you want to play around: https://www.figma.com/design/ZZrGLvQAoYWskJJImJQ4Fa/Container-radius?node-id=0-1&t=57AaN5tDbm8bBlIT-1
Will do.
Thank you,
Emma
Hi Emma,
Thanks for sharing that! I apologize for the misunderstanding. The ⌥Option ⌘Command command copies and pastes properties. So, when you use ⌥Option ⌘Command V, the radius from the original image is also applied to the target frame. That’s why the radius of the frame became 0.
You can find more details here:
If you use ⌘Command C + V instead, you can place the image within the frame without losing the radius.
I hope this clarifies it but please feel free to let us know if you have further questions!
