Hi, I have exported a lot of things on Figma, but whenever I try to export a heart. part of it gets cut off (like it moved over to the right and leaves a white space on the left).
I have tried exporting it in PNG, JPEG, SVG no matter what I do it gets cut off.
Hey Jon, are you able to share a screenshot or recording of what you’re seeing on your end?
Some things to double check though is the properties panel to make sure that the x/y values are on whole pixels. Another thing that might be happening is if you have additional frames that you’re accidentally exporting. A quick way to see this is by entering Outline Mode. You can do this via the command+y shortcut.
If you’re able to share more though, I’d be happy to take a closer look.
