How to "flatten" a logo with blend modes?
Henry_Chandler
I have a (pretty basic, needs revisions, ignore that) logo that is made of two rounded triangles that merge together with the Darken blend mode in the middle. I want to be able to get the middle part to be a separate shape so that I can mess with it’s color without changing the other two.
I have tried tracing the shapes. I am very bad at tracing the shapes. I am wondering if there’s an easier way where Figma will “flatten” the individual shapes so that I can move them around separate from each other.
Sorry if my question doesn’t make any sense! I’m bad at this.
I know that I should be using Illustrator. Sorry, but Figma’s all I got, so help me if you can.
If it helps, here’s what the logo looks like: https://imgur.com/a/xTQsuJX
Best answer by tank666
  1. Remove the blending mode from the triangle;
  2. Group two triangles;
  3. Duplicate this group;
  4. Use boolean operations to select “Intersect selection” for the duplicate group;
  5. Set the desired color for the central part.
  • 4873 replies
  • June 15, 2021
Zlatko
  • 38 replies
  • January 31, 2023
I applied a blend mode and opacity to a few visual ornaments I use in the design. However, I want to export them as flattened, so that I can apply them in CSS without the effects. Any way that could be done?
This is my problem too. Can someone make a plugin where you can flatten vector shapes including its blend mode? PLEASEE
  • June 6, 2024
And my problem too(
  • 5211 replies
  • June 10, 2024
Hey @MarAbr, thanks for reaching out!
We merged the previous topic with this one. Please try to suggestion above and let us know if it helps!
