That shouldn’t be happening, if you only performed text changes on the master component. That will be updated on all the instances that haven’t updated his text already (on the instance). By doing a modification on the instance, you are generating an override, and those are stronger than component text, or hide/show updates.
Check that you aren’t modifying more than text, for example, maybe you created a new text element and removed the previous one, that of course, will be considered as a change, and text updates on instances will get lost.
我遇到过同样的问题,我的组件被引用之后,修改了组件中的文字,当我修改母组件的时候,子组件中已经被修改的文字内容又被覆盖了。
但是我无法复现这个问题,测试的时候都是正常的,实际项目中又出现了了同样的问题。
因为这个事情我花了大量的时间来修复影响,我认为这是一个bug,但是我无法让他复现。
+1 to Mojo. If I may add to that, the structural change within the component is also considered a change. Here is an excerpt from Figma Help page.
"Figma uses the following criteria to determine whether to preserve an override:
- Layer names and hierarchy need to match between the current instance and the variant or instance you’re selecting. This applies both when swapping instances and selecting variants"
I recommend checking whether the change would affect overrides in instances. Make a copy of the component in a separate file, make a dummy instances to simulate before publishing the component.
Figma Help Center
