"Fixed stay in place" is disabled in Figma
  • August 29, 2023
  • 25 replies
  • 43330 views
Hello! I’m trying to:
  1. make the screen scrollable vertically; and
  2. make the iPhone status bar and “scroll to top” arrow fixed stay in place
I’ve managed to make the screen scrollable vertically, however, I’m having a hard time making the iPhone status bar and “scroll to top” arrow to be fixed. The “fixed stay in place” is disabled on my end.
Please help me. I’m getting frustrated and can’t wrap my head about this 😦
Best answer by tank666
  • August 29, 2023
Amanda_Ovando
mine still doesn’t work. it’s quite frustrating
  • November 30, 2023
Sorry to hear that, @Amanda_Ovando!
Are you able to share a screenshot, screen recording, or the link to your file, so we can take a closer look?
  • December 17, 2023
Also had the disabled Prototype option “Fixed (stay in play)”
Took a couple of hours or less, figured out besides the other recommendations. The base frame cannot use "Auto Layout.
Once you shut that off select the frame you want to “no scrolling” and go to the prototype settings and the “Fixed” option is now available
I have both a header & footer fixed, with content scrolling the middle.
Tom
  • December 17, 2023
This image shows another detail.
The fixed objects need to be outside of the main content, also the footer must come first, followed by the main-header, then inside is a header and subheader row.
How this helps.
I created a demo-fig file, but since I a “newbie” I am not allowed to upload/add attachments.
Tom
  • December 18, 2023
Thanks for the screenshot. It’s hard to be sure what’s happening though. Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com, so they can take a closer look.
Erick_dos_Santos_Vieira
In the base frame, set the Scroll Behavior / Overflow to “Vertical”.
  • January 7, 2024
Fixed is disabled?
Fix while scroll was easy to use. Why to complicate simple functions?
Mae_Abigail_Banquil
Hi I figured out why Fixed is Disabled in Figma.
  1. First, make sure your frame is not under another frame. It should be on its own.
It should look like this in the layers:
Then in Prototype > Scroll Behavior > Position Fixed can now be selected
Hello, I also had the same issue and JUST FIGURED IT OUT RN IM SO HAPPY!
So I the fixed position wasnt letting me click it and i realized it was because the frame that I wanted to make fixed was clipped inside another frame other than the parent frame. when I pulled it out of the other frame and just left the layer under the parent frame, it immediately let me choose the fixed position!!! I just won in life muahahahahah:)
Chene_He
  • March 6, 2024
I Tried all the methods in this topic, this is the that really works
femsubaltern
It works for mine as well! Thanks a lot! 😊
  • June 21, 2024
Thank you for this tip!
was also frustrated about this issue
  • June 27, 2024
Sometime can be disabled, because of AutoLayout. Remove autolayout and it should work.
Isadora
  • July 3, 2024
removing auto layout on the parent frame worked for me. I forgot I had that turned on 😜 (absolute positioning would have done the same thing if I needed auto layout to stay on)
  • July 6, 2024
thank you!!! this really worked 🙂
Chloe_Cai
  • August 12, 2024
Thanks for the solution, it works for me too
Ylenia_Micci
[For newbies like me] No need to delete the auto layout. Just drag your item into the layout holding “control”. It will place it into the layout but not into the auto layout, letting you set the fixed positioning to said item.
Faith3
  • December 18, 2024
yes, it works !!!
Faith3
  • December 18, 2024
Doesn’t work, look for a solution below
Faith3
  • December 18, 2024
DAMN, now the Vertical overflow doesn’t work on another frame, although it’s long
Another irritating problem
Elliott_Andrew
Thank you. I was about to go crazy.
Helder Ferreira
Thank my friend! it works :)
Subbuvenkatesh Arumugam
Very useful!
Felipe oliveira
mark option clip content!  GL
