Bohdan3
Aug 5, 2024 11:27 AM UTC
Figma UI3 problems - component properties block shown above "Position" block
When you select component, its properties show up at the top of right panel. So block with “Position” properties moves down. This is so inconvenient and confusing 🫣
Bruh
Aug 7, 2024 4:49 AM UTC
Thanks for the feedback! I I understood your point and will share it with our internal team.
Dennis_N
Power Member
Nov 7, 2024 8:43 AM UTC
To me it already happened a few times that I changed the x/y-axis instead of the elements size because the position changed. Now I carefully need to check if I am changing the values at the right place. This costs time and could easily be fixed by having these values again back at the top to avoid elements changing their position.
