Oana_Dragomir
June 14, 2022
Export from Figma to InDesign
Hi everyone, I am trying to migrate from InDesign to Figma but I still need InDesign files. After creating the Figma documents I will need to somehow export them and work with them also in InDesign. It seems there is no way to export a document directly from Figma to InDesign. Does anybody know how to do that (maybe a plugin) or if it is even possible? Thanks
Miek
MiekSolution
May 2, 2023
@Fede_Mohr
I put the first version of the plugin on exchange.adobe.com today.
However, it will probably take a few days until Adobe releases the plugin.
It is called MkitF2I.
Espen_Sele
November 13, 2022
Did you figure this one out? I am currently doing the layout and sketches for a children’s book in Figma, and will ultimately have to emigrate to inDesign to format things properly for publishing. The setup in Figma is dimensionally correct, so my plan is to convert everything to a pdf., and then convert from pdf. to indesign, and then start applying the regular book structures. Kind of have to force things around a bit, but some early experimenting looks promising. It is a bit of a workaround, but it allows me full mobility in Figma up until the time when things need to be more finalized. Cheers
SohrabNiroo
Hey @Espen_Sele @Oana_Dragomir
The only way I have seen that works is SVG but not ideal for sure
Maybe Figma+Adobe deal will come in handy for this part next year
Miek
April 3, 2023
I am currently creating an Indesign plugin to import a Figma file into Indesign.
In other words, an export from Figma to Indesign.
My question:
Is there a need for this in the Figma community?
If so, I would make a little more effort and provide a public Indesign plugin.
Hey @Miek,
Thanks for the feedback! We’ve merged your feature request with a similar existing topic to hopefully get a more accurate gauge of interest from the community.
Kateryna_Nepochatova
April 4, 2023
Hi @Miek, that would be awesome! Looking for a solution like that.
Jenna9
April 5, 2023
@Miek this would be amazing!
Adelina_Manzos
April 6, 2023
@Miek Yes, there is definitely a need!
April 12, 2023
Is there an update on this capability yet? If not, @Miek it would be great if you could share the plugin for conversion. Thanks!
Miek
April 13, 2023
@Liliana_Bredice
It will be a while before I can provide a test version.
I will report here, will certainly need some testers.
April 16, 2023
@Miek Looking forward to the plugin, as printing books in CMYK format create blur texts due to the 0.01% movement while printing.
