As I see now variables working only in the local files. I tried to modify a design guideline, that I can manage easier light/dark mode, but after I changed the component colors to “variable colors” in the connected files (where I use this lib) everywhere changed the “orig” color, and don’t bring the orig file logic.
So as I understand now I should set the logic again 😦
if I have to move this logic again it is not really useful for bigger companies. If you could support short therm copy- paset or import -export (later publish with the components 😃 ) would be cooool
Easy reuse variables
