Do you use Spacer with Auto Layout?
I’m new to Figma and design in general. I have a case where I need to adjust spacing between elements based on their content type and hierarchy.
After searching around, I found that using a spacer seems to be the best approach for my use case. However, I’m curious to know about your approach in your design with auto layout.
Happy designing!
I use auto layouts because I want my components and layouts to be reposnsive and reflow at any size withtout having to redraw them.
Spacers are a neat attempt to workaround missing design tokens. These days you can use variables to achieve the same result without increasing layers complexity
Thanks, Pavel. Could you please share with me how you achieve flexible spacing using design tokens and variables? I did some searching but couldn’t find any information on how to accomplish this.
Sure deal
For flexible spacing, I made a simple component, like this
It’s just an auto-layout frame that holds a size element inside. This way I can place instances inside other components and be able to swap them left and right whenever I want different spacing settings.
The size element has width and height bound to my spacing tokens, whenever I change these variables all my spacing components get updated in no time
And lastly, I made them discoverable with a simple layout grid, like this
I have different colours for different values so it is kind of a neat way to differentiate tokens visually. With the layout grid, I can toggle their visibility with a Shift+G
Hope that helps mate
