Hello,
I have a problem when I export my loader to svg with a degrade
Do you have a solution to fix this?
Thanks for your help
SVG format itself doesn’t support angular gradients (this is not a Figma issue), so your only option would be to rasterize it.
Oh… ok thanks for your response 🙂
@Gleb What are the keyboard shortcuts to pixelate only this element of my Figma file?
Select the layer, use the quick actions search → rasterize
Or if you need higher resolution, you might want to export it as PNG first at desired resolution and then re-import into Figma.
