zhanghaipeng
Mar 20, 2024 7:13 AM UTC
希望在frame上增加标签,方便查找设计稿
目前我们的工作版本,会涉及很多页面,我们只会把有修改的放在新的figma文档上,这样做的结果导致一个功能模块会分布到很多设计稿里,所以希望增加在frame上添加tag的功能,我们就可以通过查找这些tag来查找文件。
ksn
Mar 21, 2024 6:42 PM UTC
Hello! If I understand correctly, you’re looking to have some sort of system that would allow you to ‘tag’ frames, so you can easily find/search where copies of them are through a file.
Does that seem correct? Apologies if I haven’t understood correctly.
zhanghaipeng
Apr 3, 2024 3:01 AM UTC
Yes, it can be understood as a tag for frames or sections, which allows me to quickly query pages with the same functionality distributed across different design documents
I’m sorry for replying you so late~~~~
zhanghaipeng
Apr 3, 2024 5:52 AM UTC
The company I work for has purchased Figma, which is used by UI designers, interaction designers, and product managers, and involves multiple personnel and versions. Our design only includes functional modifications in the new design draft. Therefore, in the long run, the same functional module will be modified in different design drafts. If modifications are made to the already modified plan, it is necessary to review many previous design drafts and search for the design draft of this functional module. Therefore, I hope to have a function that adds similar tags, such as labeling this design draft as “meeting module”, and then I can search for this tag to view all relevant content.
ksn
Apr 4, 2024 5:50 PM UTC
No worries on the later reply! I’m glad I was on the right page with your feedback. I’m going to note it for our product teams, and leave this as a feedback thread so others can give a +1
