VladVladVlad
Feb 10, 2021 4:52 PM UTC
Zoom without ctrl
On PC i want to explore figma document with only mouse, but i can’t zoom in/out without keyboard - I have to hold down the Ctrl with the other hand. On a Mac, there is no problem: gestures on the touchpad make zooming convenient.
At the moment we can scroll through a document by dragging it with the left mouse button or by scrolling horizontally, but to scroll horizontally (which is also often used as vertical scrolling) you have to hold down Shift, which is rather illogical for a map-like interface.
Can you add a switch like the existing “Invert Zoom Direction”? That would solve my problem.
This feature was already requested in 2017: https://spectrum.chat/figma/feature-requests/zoom-with-mouse-wheel~04d1784d-827c-4363-9404-ffddc91bcfef
Thanks
Vlad
Iya
Aug 5, 2023 4:32 PM UTC
Thanks a lit for sharing! But would you agree simply zooming in&out can achieve what you are doing a little easier and is more straightforward?
Iya
Aug 5, 2023 4:36 PM UTC
The reason I don’t like zooming while holding down a key is because I am moving around a lot.
PS & AI can work with alt key zoom is because people are pretty much always staying on one image. The demand to move is much smaller. They don’t have to jump between 30 frame to keep track of things.
esn1
Aug 6, 2023 12:43 PM UTC
we NEED this feature please
esn1
Aug 6, 2023 10:40 PM UTC
it doesn’t work. do i need to do anything else after running the script?
DanDixon
Aug 20, 2023 5:14 AM UTC
I just saw your post. Sorry, you’re having trouble getting it to work. Once you run the script, it should just work. I have this script set to run whenever I start Windows.
My script assumes you’ve got a recent copy of AutoHotKeys installed, are using Chrome or the Figma app, and that Figma is using a default dark color scheme (not sure you even can change that).
I just posted an updated script) that uses AutoHotKey v2 along with a zoom multiplier feature, easy way to turn the color debug tooltip on, and a quick text replacement test to see if AutoHotKey is working.
Try this:
1 - Confirm you’re running the latest version of AutoHotKeys. If in doubt, just install it again.
2 - Update your script to the latest version (copy and paste from the updated post above)
3 - Run the script. Then in notepad (or any text editor should work) type: ahktest (then a space or press enter)
That should be replaced with: Test Sucess - Autohotkeys is working
Does that help? Does the typing test work?
esn1
Aug 28, 2023 12:49 PM UTC
just wanted to give you a big thanks from the support and update, the scripts runs well, but i can’t make it to work on chrome (just in the app it works). but i take it! <3
Takahiro_Kinoshita
Aug 28, 2023 2:02 PM UTC
This is a sensitive and very useful question. I have encountered these usages many times when using ipadmini and mouse. I would like to have this issue resolved.
Gil_Umanski
Aug 29, 2023 10:00 AM UTC
After Adobe purchases Figma, it is to time to make it the same as adobe: Alt+scroll
Iya
Sep 2, 2023 11:12 PM UTC
Yes please we need this feature implemented.
Imagine the amount of users who will move away from Miro to use FigJam
Sep 10, 2023 9:29 PM UTC
Specifically my team decided not to move away from Miro because of this feature. It’s an accessibility issue for some of our disabled users.
