Alessandro Manzo
Will the grid layout be available within the new Figma Slots before the end of the Beta?
I’ve already started using the new slots and I find them amazing, but I think it’s very limiting to prevent the use of grid layout.
Thibault GRONDIN B.
Same issue for me !
Tiziano
March 12, 2026
I really don’t understand Figma lately… WTF?
Tiziano
March 12, 2026
Hello everyone! I’m happy to tell you that slots is now rolled out to all Full seat users. If you're unable to access the feature, refresh the design file and check if you have edit access to it.
If you do not see the feature after that, please reply or PM me so I can have someone take a look. Enjoy!
How does Slots not support Grid Layout is beyond me! Seriously… Please implement features properly.
Smith_Samuel_D
March 13, 2026
Hi folks! 🤠 I found a simple, not-too-hacky workaround for now. Wrap your Grid frame with an additional frame and then convert the outer one to a Slot. It works perfectly, but it does sort of undermine the Slot property in the properties panel, since you wouldn’t want to actually add anything there. Hope this helps!
Tiziano
March 14, 2026
Hi Samuel,
thanks, this does “work” and makes it at least behave like desired, but sadly no long-term solution as this is basically a detached component without tokens :/
Figma, please add support for grid, why would you remove it anyway???
Tiziano
March 14, 2026
​@djv when will this be available?
Martin_Kulhanek1
Please make grid layout available for slots.
ryan.nelson
This wipes out like 1/3 of my use cases for slots :(
AscendJoe
This is disappointing to see its not available as this is the reason I wanted slots.
The goal was to make a content grid with areas for bleed, wide and regular content. Drop the component into the page and then be able to put content into the area you wanted, should be as simple as that.
I feel like Figma has overly complicated components and now slots.
Matthew_Ryan
May 15, 2026
+1 for supporting grid on slots
