Edward Garrity
Aug 10, 2026 6:09 PM UTC
What happened to 'Go to Source' in Make?
The recent update of the Make panel UI has seemingly removed the ‘Go to Source’ button when in edit mode. You used to be able to select an element in the app, then go to the source code.
The code would be highlighted for you and you can then make manual edits without the struggle of scrolling and navigating through the code to find the element you want to edit.
Please bring back this feature!!
Matthew_Wioncek
Aug 13, 2026 6:38 PM UTC
I found it in the top right on the second toolbar underneath the Share button.
Mario_Noble
Aug 19, 2026 8:29 PM UTC
I only see the Edit action but nothing which enables us to jump to a block of code like before. The Elements shows the component tree but that’s not helpful to jump to the code. Am I missing something?
Matthew_Wioncek
Aug 19, 2026 8:45 PM UTC
When I select something with the edit control I have a “Go to source” option in the black menu that appears upon selection.  That jumps me to the code block.
Mario_Noble
Aug 21, 2026 1:24 PM UTC
Thanks. It’s still not showing up for me. Maybe Figma is doing some A/B testing. Hating this because it makes it harder to track down elements to make edits. The Elements hierarchy pane doesn’t really reflect what file it is in.
