OG_Can
Jun 27, 2023 10:27 PM UTC
Use percentage for size variables
Hello. I was wondering if it is possible to have percentage values in variables, like setting percentage value for frame widths or shape sizes (etc.) that have variable modes applied to them? Percentage values could respond better to content that varies within a frame or frames within frames.
Nora_Leca
Sep 24, 2024 11:53 PM UTC
+10000, I find responsive designing for handoff to devs SO tedious, borderline unusable in Figma, without a whole lot of variable malarky to set up breakpoints with max & min widths for like 5 screen sizes.
If percentages were just a thing, it could be truly fluidly responsive for maybe just 2 screen sizes, mobile & tablet+, and usable outside of the flexbox ‘fill width’ model which doesn’t allow for fully custom design by a grid (5/3 columns designs on an 8 column grid, 6/3 columns on a 9 column, etc).
Johan_Eilertsen
Oct 7, 2024 12:53 PM UTC
This is needed! Any progress Figma crew?
Allen_Z
Nov 5, 2024 3:40 PM UTC
So development time from Figma was used on a new UI that is not as functional as the previous UI was, but percentages STILL haven’t been added?! Come on Figma! Get your priorities straight. Give the users what they are ASKING FOR, not what you hope they will like.
dbybanez
Nov 8, 2024 2:02 PM UTC
+100000 This would definitely help when designing data tables especially when you want a column to have a specific percentage based on the table’s width.
Phil_Wornath1
Nov 8, 2024 2:19 PM UTC
Needed here as well - be it allowing float values (e.g. 1.2) or even 100% as string would do. But strings are not allowed - why? . Now we need to manually convert all values later in deployment have another manual conversion sheet for all the font styles…
ilil_hitin
Nov 14, 2024 3:35 PM UTC
Does Figma developing a percentage for size variables?
It is crucial for building cross-platform applications as there are countless screen sizes…
Cristian_Ghita
Nov 21, 2024 11:07 PM UTC
this is crucial. use cases are endless. Especially since designing fluid layout’s is becoming more and more crucial with the rise of foldable devices
Mathias_Stav
Dec 4, 2024 2:02 PM UTC
Not being able to use percentage in variables for line height is a huge blocker. Could you flip it around and instead make it possible to interpet numbers as a percentage value if used in line-height? I mean, we already have the possibility of defining percentage in the line height field. Please look into this 🙏
ari3
Dec 17, 2024 12:39 AM UTC
This is such a frustrating gap in Figma’s abilities. I can’t fathom why it’s not a priority.
Chien-Ju_Peng1
Jan 23, 2025 10:17 PM UTC
We are building the design system using variables, and we need letter spacing to support the percentage value variable because we need to quickly convert from percentage to em instead of using the pixel.
