The
Jul 5, 2024 12:57 PM UTC
UI3 - Show Layout Properties (Width/Height/Fill/Hug)
The idea of combining Layout and Auto Layout settings is cool, but the idea of merging two categories of input fields into one is not. It makes the workflow worse, because both settings are important and often you need to see them at the same time. But now Fill/Hug is always visible, and height/width disappears if there is auto layout.
Now to find out the size of an object you have to either 1. look at the bottom edge of your frame (not always possible, you have to scroll down if it’s long), or 2. move the cursor over the size input field (which is a time-consuming movement), or 3. make the right panel very wide (which eats up the working area).
There’s no benefit to combining important settings. In any case, even in the new interface there are so many of these settings that they go into the scroll anyway.
So please let these inputs live separately ❤️
(video demonstrates the problem described above)
Ishan_Jalan
Oct 2, 2024 5:14 AM UTC
Was about to make a new thread regarding this until I found this. This is one of the biggest things I miss in UI3. I really need to see Fixed/Hug/Fill without hovering on W/H values.
The
TheAuthor
Oct 3, 2024 3:21 PM UTC
They have already fixed it! Yes, they didn’t split the inputs, but they made the change so that now dimensions are not lost even if auto layout is enabled and even if the right panel is in the narrowest position.
Ishan_Jalan
Oct 3, 2024 4:47 PM UTC
But you need to hover on it, I can’t find the pattern when it shows it vs when you need to hover on it. I just want it to be visible without me needing to interact with it.
The
TheAuthor
Oct 3, 2024 5:52 PM UTC
You no longer need to hover to see the dimensions, now both parameters are shown at the same time (I showed it in the attached video)
Ishan_Jalan
Oct 3, 2024 6:41 PM UTC
When it is fixed, it doesn’t show “Fixed”, sure I can get used to it but why show it only for Hug and Fill but not Fixed?
The
TheAuthor
Oct 4, 2024 5:21 PM UTC
Well, the absence of the inscription can be read as “fixed”. Because all elements are initially in the fixed status, so this is the “default” status, which is not marked. Honestly, I don’t see a problem with this.
The main problem has been solved, now you don’t need to make extra mouse movements to see the sizes (which I am very happy about)
