Sebastian_icon
Mar 28, 2025 3:06 PM UTC
trigger events from a Prototype outside of Figma
Issue
We want to implement Figma prototypes in a multi-layer application, which can contain all sorts of other files, like Unity, Unreal, Protopie and they can communicate with each other.
The Figma prototype would run in an iframe and we need a way to listen to events from the Figma prototype, in order to create interactions between the Figma prototype and other applications.
It seems there is currently no way to make Figma work in such an environment.
Feature Request
I imagine there could be an additional option in the interaction window, so that I could add an event to be triggered when a button is clicked. And the iframe which contains the Figma prototype should dispatch this event to out custom JavaScript.
tank666
Mar 28, 2025 3:23 PM UTC
Embed API doesn't meet your requirements?
Sebastian_icon
Mar 31, 2025 9:02 AM UTC
thanks for the hint! ChatGPT didn’t know about this 😅
It seems that the Embed API will enable us to do what we need. However, since it all depends on node-ids, it makes it much more complicated than I imagined.
To trigger specific actions by clicking a button, I have to map all the node-ids before to figure out which button was clicked and then determine for each single button, which event to trigger.
It would be much easier to directly define the events in the interactions in Figma. Multiple buttons could trigger the same event, etc.
