Bart_Vlaemynck_Belfius
Jun 28, 2024 1:43 PM UTC
Text-style overrides like bold, underline, ... bug on instances
Text-style overrides like bold, underline, … won’t work on instances properly, now the instance must be rest for the bold overrides to come though. So a lot of screens needs to be rechecked and manual work is needed everywhere the instance is used.
Any solutions for this?
AntoineP
Jan 17, 2025 2:20 PM UTC
+1 Same need here, I’m amazed that I didn’t run into the issue earlier.
Shiv
Mar 3, 2025 6:48 PM UTC
​@Junko3 Do you have any updates on this? This is a 8 month old thread and we’re also running into the same issue.
Rohith_Kumar
Apr 15, 2025 10:23 AM UTC
Oh no. It’s still an issue. Do I need to create a link style to avoid this?
Hi ​@Junko3, Any update on this issue?
Lee_Beth_Kilgore
May 2, 2025 8:30 PM UTC
me too.  I have to detach my instance just to change text styles.  this is an intermittent and inconsistent problem for me.
Patrick_Flanagan
Dec 1, 2025 2:37 PM UTC
Not sure if this is the same issue, but it is really close.
Start by adding a text block, type any text in there you want.
Make that block a Component, and add in two more variations.
Change the colors of the other variants.
Select the boundary box for the component and add a Text Property.
Drill down on each variant to get to the text and apply the Text Property you just made. (all still good)
Apply an underline to one of the variants. (mine all underline at this point)
Change the fill color for the text on one variant. (DING!) They all change?
Only seems to happen when I add in the underline?
SEWOBE
May 15, 2026 12:21 PM UTC
Hi @Junko3, are there any updates on this issue?
I’m still experiencing the same bug, and it seems to remain unresolved after several months. Would appreciate any status update from the team, especially whether this is currently being investigated or planned for a fix.
gimaf
May 19, 2026 9:04 PM UTC
Man this is very very bad.
How is it possible that this is really a feature and not a bug? What’s the rationale behind this choice?
