uxfs
Sync from Github the Figma Make
Figma Make is the best prototyping tool I have seen so far (yes, better, or at least more time efficient, than V0 and Claude Code for now). It also has an integration with Github, which is suuuper cool. Now… it would be REALLY gamechanging, if the connection with Github was a two way sync. If edited code could be pulled back into Figma Make, for team collaboration across multiple platforms. I understand that this is really tricky, because Figma Make can't interpret all types of code… but I'm putting it out there…
trivial-coder
I also urgently need this feature. My current work around is to make changes in VS Code and manually copy them back to Figma Make in the code editor.
Nonetheless, to put the pressure on: lovable already has a 2-way git integration! And the code generated by their LLM is much cleaner than the slop created by the LLM used by figma. Since my current workflow of editing the code is so frustratingly cumbersome I'm currently in the process of abandoning figma make and switching to lovable completely.
rajitha disanayaka
100% Agreed on this. 🙌
Louis Lallemand
I totally agree, it would be super helpfull. Do you think we will have this kind of feature added one day ?
Rodrigo Melón
We need this!!! 🙏🙏🙏
Lauren Serota
This integration is the only thing that will keep me in Figma (instead of moving to using something like Cursor exclusively), and not having it is the reason I don’t use Figma profusely ATM. Hope it gets implemented. Happy to answer provide more input and feedback if useful.
Ozan Kulaksiz
This is an URGENT needs for Figma make
BrainyBoone
Tell FigmaMake to ADD this feature for itself. 😗
Samuel Simental
Just made a forum account to say that this Feature should be a must!
Uxomnia
Je valide aussi cette fonctionnalité, je contourne ce problème avec vscode puis réimport manuellement mais c’est contraignant…
Merci d’avance
SpaceParrots
I think this feature is very much needed! If figma make can’t render the page anymore, just roleback - that’s what git is for!
