Duc_Dao
Aug 11, 2025 4:34 AM UTC
Swap library: Select all action & Optimization
I’m working on swapping the library for a large design file. The process uses so much memory that I can’t swap all components at once. I have to manually pick which components to swap. However, when I open the swap library modal, every component is already selected by default. This means I have to uncheck everything before I can select only the components I want.
So how about:
  • Select all option for swap library
  • Optimize swapping library so that it won’t crash in the middle of the process. I don’t mind waiting for 30 minutes.
Thanks.
