Eli_Crow
Feb 28, 2021 4:19 PM UTC
Support "on click outside" or "blur"
Immediately sticking out for me is the absence of a “blur” interaction. This is necessary to simulate “focused” states in things like drop-downs and text inputs.
Without this, my components get stuck in the focused state without an elegant solution for having them blur like they do on the web.
My current workaround is to use the “mouse leave” action, but this is suboptimal.
I imagine you could add a trigger called “Click Outside” or something similar.
Besides this, the feature is a golden so far 🙂 You folks are killing it!
Jul 10, 2023 10:09 AM UTC
@Figma_Support
Do you have any plans to implement this “on click outside” trigger option?
It would be invaluable in creating true to life prototypes.
Jul 14, 2023 6:54 PM UTC
I’ve wanted this many times- Figma, please do this.
Scott_Clark
Sep 17, 2023 8:29 PM UTC
So this is actually a simple fix.
If you have something like an expandable search field that you want to close when you click outside of it. You most likely have this component assigned to a variable. So do something Like this:
Component = String Var Name = (values) default, open
the component opens when you click on it.
Once you have things built. Just add a conditional statement to the screen as an On Click conditional statement that tells open things to close. So you basically just click in the negative space of the screen and anything that is open will change to it’s closed state. The close trigger is the frame. To you don’t add a close trigger to the component because you aren’t clicking on it.
If Component == “open”
  • set component to “default”
Dec 13, 2023 4:39 PM UTC
Great! however I cannot use it. Say to upgrade the plan 😕
Jun 28, 2024 5:20 AM UTC
do you mind sharing a live example of this? I think it would be very helpful for those not so knowledgeable about this type of conditional logic. I know I would learn a lot from it. Thanks!
Vincent_Schlothauer
Aug 14, 2024 9:25 AM UTC
While this works on an individual component level, it’s still a huge pain to implement once you have more than one or two components that can be focused/unfocused or open/closed on the same screen.
Say you have a form with 10 inputs and dropdowns. Not only do you need to create a “focus: true/false” variable for each separate input, you also need to both create an on-click event that sets every single one of them to false when clicking in the empty space, and create the same on-click event for every component on screen, so that focusing the next input causes all other inputs to lose focus.
This seems like a very unwieldy workaround simply to avoid having a “click outside” trigger (which already exists for overlays).
Laura_Sujei_Vega_Magdaleno
Aug 29, 2024 10:50 PM UTC
same here, I also had the same problem
Rcherem
Apr 10, 2026 6:37 PM UTC
I came up with a bit of a workaround: inside the component where I’m defining the interaction, I add a transparent frame (around 1600×1600), position it absolutely in the center, and use it as a trigger to detect outside clicks.
