Shen Lee Design
Apr 12, 2025 3:47 PM UTC
Suggestion: "Repeat Last Action" Shortcut for Efficiency
Hi Figma Team! 👋
I'd like to suggest a "Repeat Last Action" feature, a simple shortcut that lets us repeat the most recent action (like resizing, renaming, applying styles, etc.).
This would be super helpful when handling bulk updates across 100+ visuals. While we can replace assets using ‘Select all with’ same instance, variant or same properties, it doesn’t always update everything correctly. I still find myself going through the visuals to double-check and manually adjust the ones that didn’t change as expected.
Although there are some relevant plugins, they don’t quite solve the issue or work consistently in every scenario.
Having a built-in shortcut to repeat the last action would really speed things up and reduce the tedium of making the same change over and over again.
Thanks Figma for the amazing work, hopefully my little wishlist will come true someday! 🙏✨
Lucian_Tudorache
Sep 7, 2025 6:35 PM UTC
I’ve just wanted to suggest the same feature, would be a great addition! @figma!
