Alex Costa
Feb 22, 2025 4:15 PM UTC
Struggling with Converting Figma to Elementor? Share Your Challenges!
Hey everyone,
I've noticed that the transition from a pixel-perfect Figma design to a fully functional Elementor build can sometimes be more complicated than expected. Whether it's aligning responsive layouts, dealing with plugin limitations, or managing custom code and design tokens, many of us have faced hurdles along the way.
Here are a few common issues that often come up:
  • Responsive Design Breakdowns: What looks great in Figma doesn't always adapt well in Elementor.
  • Plugin vs. Manual Conversion: Automated plugins may save time but often compromise on precision or flexibility.
  • Integrating Custom CSS/Code: Sometimes achieving the exact look requires extra tweaking and manual code adjustments.
  • Component Consistency: Keeping design tokens and shared styles uniform across projects can be a real headache.
  • Workflow Efficiency: Balancing speed with quality when recreating complex components.
I’d love to hear from you—what specific challenges have you encountered when converting Figma designs to Elementor? Have there been any particular elements that just don't translate well, or are there workarounds you've discovered that make the process smoother?
Drop your problems and experiences in the comments below. Your insights might just be the key to solving someone else's puzzle!
Looking forward to a great discussion!
drzivil
Nov 5, 2026 3:38 PM UTC
Good list. I’ll add what we ran into, because we build a Figma to Elementor plugin (ready→made, disclosure: it’s ours) and these exact points cost us the most time.
Responsive breakdowns. Most of the trouble comes from fixed pixel sizes. A Figma frame is 1440 px wide, and if that width is copied into Elementor literally, the phone view breaks. What helped us: turn auto layout into flex containers, make wide paddings and font sizes fluid, and pull everything visible inside the phone width. The design needs to be built with auto layout, though. Absolutely positioned layers stay hard for any tool.
Plugin vs. manual. The real question is whether the result can still be edited. If you get one HTML widget, or a pile of containers with inline CSS, you rebuild by hand anyway. If you get native containers and real heading, text, image and button widgets, you can keep working in Elementor as usual.
Custom CSS. Some things Elementor has no control for, like certain gradients or blur effects. We put those into custom CSS on the element itself instead of dropping them, so they stay in the right place and can still be found.
Component consistency. This one is still partly open for us. Repeated components come out the same each time, but Figma variables don’t map cleanly onto Elementor’s global colors and fonts yet.
Workflow. For us the biggest gain came from converting section by section instead of whole pages. A section is easier to check, and if something is off, you redo only that.
If anyone wants to see how a plugin handles their own design: I’m happy to convert a frame and show the result, including the parts that don’t come out well. Plugin:
https://www.figma.com/de-de/community/plugin/1492108013732875788/figma-to-wordpress-elementor-gutenberg-oxygen-readymade
Sarah Anthony
Nov 29, 2026 6:35 AM UTC
Great list, Alex, and the responsive breakdown is the one I see most often. A 1440 px Figma frame with fixed widths, tight spacing, and desktop-only thinking rarely survives contact with Elementor on tablet and mobile. What helped me was rebuilding section by section, starting with the header, footer, and one repeatable section, then setting global colours, type scale, and spacing in Elementor before touching individual pages. That keeps components consistent and makes later edits far less painful.
For custom CSS, I keep it in a small shared place with a short note on what each rule does, so a future edit does not break a gradient or blur that Elementor cannot handle natively. I also test every section at 1024, 768, and 390 px before moving on, rather than checking responsiveness at the end.
For a worked example of this design-system-first approach, see this Elementor build guide: https://shahzadishaq.site/elementor-website-design/ - it shows how global styles and Theme Builder templates keep a site editable and fast.
