Aliya Afreen
Jul 29, 2026 11:29 AM UTC
String, Number and Boolean Variables Not Appearing in the Right Panel (UI3)
Hi everyone,
I'm learning Figma Variables and I'm facing an issue that I can't figure out.
My setup:
  • Figma in Google Chrome
  • Free (Starter) plan
  • Personal Draft file
  • Latest Figma UI (UI3)
What's working:
  • ✅ Color variables work perfectly.
  • ✅ I can create String, Number and Boolean variables.
  • ✅ I have set the correct scopes (e.g. String variable includes Text content).
The problem:
  1. String Variables
    • I created a String variable (e.g. Sign In Button with the value Sign In).
    • According to tutorials and the Figma documentation, I should be able to bind it to a text layer's Text Content.
    • However, when I select a text layer, I only see variable options for typography properties like Font Size, Font Weight, Line Height, etc.
    • There is no option to bind the actual text content.
  2. Number Variables
    • I created Number variables.
    • They don't appear for properties like Corner Radius, Padding, or other numeric properties where tutorials show they should.
  3. Boolean Variables
    • I created Boolean variables, but I can't find where to use them either.
I've already tried:
  • Creating a brand-new file.
  • Creating new variables.
  • Checking variable scopes.
  • Selecting normal text layers (not instances).
  • Using a rectangle for Number variables.
The problem still exists.
Is this a bug, a UI3 change, a gradual feature rollout, or am I missing something?
Any help would be greatly appreciated. Thank you!
