Ward_Josh
Oct 22, 2025 5:06 PM UTC
Stop Forcing Me to Open Figma at Login
This is so annoying. I shouldn’t have to use the web version to disable this. FIGMA should allow me to turn this off in the settings. I don’t use Figma every day and I certainly don’t want it to open every time I log in. Clearly, this has annoyed several users but you fail to listen.
STOP FORCING ME TO OPEN FIGMA AT LOGIN!!
    Marc8
    Jan 28, 2026 11:00 PM UTC
    ​@Marc8 To uninstall it and just run the browser application instead is literally the dumbest suggestion ever. I know you don’t work for Figma, but uninstalling or using the browser isn’t a real solution. The issue is that Figma keeps adding itself to login items without consent and resets it on updates. That’s bad UX. There should be a simple setting inside Figma to control this, like almost every other app does.
    If using the desktop app is causing an issue, how is using the browser version not a solution? I didn’t say it’s a catch all solution, it may work for some users.
    Raise your concerns on the master thread for this issue, dont @ me.
    Fredrick Astare
    Nov 22, 2026 11:20 PM UTC
    You could try removing the login agent and replacing it with a fake stub. Then lock down perms on the imposter agent so Figma doesn’t nuke it the next time you start the app or login. Something like:
    rm -rf ~/Library/Application\ Support/Figma/FigmaAgent.app
    touch ~/Library/Application\ Support/Figma/FigmaAgent.app
    sudo chflags -R schg ~/Library/Application\ Support/Figma/FigmaAgent.app
    Note: doing this will likely cause issues with the browser version of figma loading local fonts.
    If you are building a figma site, then loading web fonts from cdn will remedy this (what you should be doing eventually anyway.. one step closer to production in this case).
    If you need to reverse it:
    sudo chflags -R noschg ~/Library/Application\ Support/Figma/
    Then delete the dummy agent & relaunch figma.
    Or if you are on a new mac OS like 27, you can describe a shortcut that checks for the agent when you quit figma or go to power off or log off. Same with login in.
