Ward_Josh
Oct 22, 2025 5:06 PM UTC
Stop Forcing Me to Open Figma at Login
This is so annoying. I shouldn’t have to use the web version to disable this. FIGMA should allow me to turn this off in the settings. I don’t use Figma every day and I certainly don’t want it to open every time I log in. Clearly, this has annoyed several users but you fail to listen.
STOP FORCING ME TO OPEN FIGMA AT LOGIN!!
    Arthur Grau
    Dec 19, 2025 8:25 PM UTC
    @Figma, this has been going on for years. Please turn this off, or create a setting that allows us to turn it off. No application should force itself on my system. This is terrible user experience. You have nearly ten thousand replies to threads related to this on your forum. TURN IT OFF.
    Marc8
    Dec 22, 2025 2:31 AM UTC
    That’s a system level issue - just remove it as a startup app/login item from your system settings ​@Arthur Grau ​@Ward_Josh
    Arthur Grau
    Dec 22, 2025 2:53 AM UTC
    I do that, but it's really poor experience to have to do this extra work on behalf of Figma every time the app has an update. I've encountered no other app in over 20 years that has this foundational problem. Just make a setting in Figma so I can turn it off. I shouldn't have to change my system settings on each update.
    Ward_Josh
    Ward_JoshAuthor
    Dec 22, 2025 12:40 PM UTC
    ​@Marc8, we shouldn’t have to remove Figma from login items every time we update or launch the app. This is a very annoying user experience. I agree with ​@Arthur Grau, no other application does this. Not all of use Figma every time we boot or login into our machines. There’s thousands of people requesting this same thing. Just because it opens at login doesn’t mean we’re going to use it. We have other applications running that we need CPU usage for. Stop forcing this application on us. If I want Figma to open at login, I should be able to set it myself. Fix this.
    Ward_Josh
    Ward_JoshAuthor
    Jan 6, 2026 1:17 PM UTC
    ​@Marc8 This is annoying.
    Marc8
    Jan 12, 2026 1:32 AM UTC
    Uninstall it and just run the browser application instead
    Ward_Josh
    Ward_JoshAuthor
    Jan 12, 2026 12:23 PM UTC
    ​@Marc8, that’s just as annoying. Why are you forcing people to open Figma?!?!
    Ward_Josh
    Ward_JoshAuthor
    Jan 14, 2026 3:09 PM UTC
    ​@Marc8, Why are you forcing people to open Figma?!?!
    Marc8
    Jan 14, 2026 8:50 PM UTC
    Not sure why you are following up - I don’t work for Figma
    Marc8
    Jan 28, 2026 9:00 PM UTC
    ​@Marc8 To uninstall it and just run the browser application instead is literally the dumbest suggestion ever. I know you don’t work for Figma, but uninstalling or using the browser isn’t a real solution. The issue is that Figma keeps adding itself to login items without consent and resets it on updates. That’s bad UX. There should be a simple setting inside Figma to control this, like almost every other app does.
    If using the desktop app is causing an issue, how is using the browser version not a solution? I didn’t say it’s a catch all solution, it *may work* for some users.
