cynosoura
Dec 25, 2025 2:16 PM UTC
Single-node vector dots
There’s an issue I keep encountering every time I have to work with vector icons - you cannot have a flat, fully linear no-fill icon which has dots in it. You have to have two separate layers - one linear with just a stroke and no fill, and one which contains all the dots as filled circles without a stroke. This makes it hard to control transitions and is overall annoying.
Please consider adding the option to create single-node dots that would be controlled by the stroke variable only, like a line of length 0, so that we wouldn’t have to add circles to linear icons.
P.S.: or just make sure that the fill colors are preserved across instance swaps regardless of the amount of layers and aren’t reset to the inserted element’s default color, destroying my transitions. That would work too. At the moment instance swaps only consistently work with single-layer linear icons.
