Robert_Rutherford
May 6, 2021 1:45 PM UTC
Showing distance to objects while dragging
I know If I use the option key and hover, I get the distance between objects but I would like a feature that shows the distance exactly the way the option key does but without start making a copy of the element. If I start moving it I just want to see the distance to the element above for example. If I do this now it’s going to get to a point where it starts measuring from the copy I’m holding.
Figma1
Apr 7, 2022 10:11 PM UTC
Here you can see the marks shown by the guide are based on what your mouse is hovering over.
You can hold alt and hover over an object to see the distance and then use your keyboard to move your selected object and it will update the distance.
Animationasdf23
May 3, 2022 3:42 PM UTC
alas! I don’t know if somebody already found out, but you can see all the red measurements by clicking inspect in the right side panel along with the design and prototype. they won’t go away unless you decide to go on another panel. no need to hold alt/option.
fadel_muhammad
Jun 19, 2022 8:28 PM UTC
Thanks for the tips Figma 1! ☺️
Abhishek_Rawat
Jul 10, 2022 1:33 PM UTC
You can do something similiar.
  1. Select Element.
  2. Press alt and hover over element that you want the distance.
  3. Use arrow keys to move the selected element (While pressing alt and mouse arrow hover on other element)
Kahan_Bhalani
Aug 5, 2022 3:54 AM UTC
This is the perfect workaround until Figma implements it in future releases. Thanks.
Nicholas_Navarra
Jul 6, 2023 5:21 PM UTC
Thank you!
Eric Hill
Aug 30, 2025 5:13 PM UTC
  1. While holding the Alt/Option key down, drag the object. This will also make a copy of the object, but…
  2. Before you drop the object, release the Alt/Option key and wait a second. The original object (the one in the location before the move) will disappear.
  3. Drop the object.
You have now moved the object with distances shown without making a copy of it.
Kickpedal
Feb 22, 2026 8:54 PM UTC
  1. Select Element.
This worked perfectly and is the only explanation for the problem I was having. Thank you!
