john-mainboard
Feb 25, 2026 1:51 PM UTC
SHARE LINKS :: Make a third panel for Share Links
Next to Prototype tab add a THIRD tab called SHARE:
  • Here we can add BOTH the VIEW/EDIT link + the PROTOTYPE LINKS as panel sections
  • Then we can setup a starting point and also control the permissions of the share links.
  • It doesn’t seem to be an easy way to add these to the FLOWS section, hence adding it as a new SHARE tab
If possible, the share links should also be accessible WITHOUT opening the file in a pop-up dialog maybe with two tabs for View/EDIT and Prototype.
