Baffour
Jan 3, 2023 3:31 PM UTC
Set Default Section Colours in Figma
Hi, I wanted to suggest preset colour options for Sections in Figma, similar to FigJam.
The default grey colour blends into the default canvas background meaning I always need to choose a custom stroke + fill after using it. It’s an easy task but it breaks my flow to have to stop and change the colour of a section in the middle of whatever I’m doing.
To be honest you could improve this just by changing the default colour from grey, but having some of the FigJam presets makes it a lot easier if you have different colour sections for categorisation.
TJ12
Jun 11, 2024 5:36 PM UTC
+1. We need more QOL improvements like this in Figma.
Zoe_Gomez
Jun 21, 2024 1:12 AM UTC
I would love this. Even just somewhere in the admin settings to set what the default section colour is would seriously help.
Aaron_Xu
Aug 27, 2024 6:34 AM UTC
+1, and I highly recommend use global variables to manage all default style instead of “Set default properties” in Edit menu. It keep the logic simple.
More detail explanation: a place, may be in Figma setting, there are some variables like “Frame’s default background”, “Section’s default stroke”, use can set object’s default style by edit those variables.
Ellie8
Aug 29, 2024 9:45 AM UTC
This would be really helpful for me. I work on app pages with a white background, so I always have to change the default white background in sections to make sure it doesn’t blend in. Changing the section colour by default would be really helpful.
Sep 18, 2024 5:34 AM UTC
To help with this, I created a plugin called Quick Section that lets you set a default color and create sections. You can also add section headers that align with selected layers and set up app shortcuts for extra speed. Hope it helps! 🙂
Zoe_Gomez
Nov 13, 2024 11:57 PM UTC
frustrated by the lack of this feature again today
Lehel_Babos1
Aug 13, 2025 12:27 AM UTC
This would be great to have so I don’t have to constantly manually change this.
b7s9
Nov 14, 2025 3:00 PM UTC
I need this feature because it’s slowing me down to need to change it every time so my designs with white backgrounds don’t blend in. “Set Default Styles” did not work for me
Nick_BLK
Jan 29, 2026 6:19 PM UTC
Came here to state all of the above concerns. Please fix this.
Shailesh Saravanan
Jul 28, 2026 5:50 AM UTC
Yes please! Also, would be nice if I could select the frames I want and press Shift+S to create a section around them. And I would like to set a default padding around the selection, fill colour, and stroke for the section.
