Victor_Morales
Dec 12, 2023 8:14 PM UTC
Select which properties to expose on nested component instances
Lately I’ve noticed that when I have several nested components, I would only like to be able to modify some and not all. This would allow the component that draws on other components to have efficient adaptability in its contextual use.
I am setting the variables for the Button component using variables and would not like the size property to be exposed so that the component has a desired behavior based on the active variable.
Patrick_Flanagan
Feb 5, 2026 2:26 PM UTC
I would also like the ability to re-order the properties of nested instances as well. I have nested components that get to be five or six layers deep, would be great to move the ones that are really needed for my particular component variation to the top for easy access.
Roman Vert
Apr 7, 2026 10:42 PM UTC
This is a fundamental gap in how component composition works in Figma today.
When building higher-level components (organisms) from smaller ones (atoms/molecules), we often need to expose only specific properties — for example, text content or a single state — while keeping other properties fixed to enforce consistent behavior.
Being able to explicitly select which nested properties are exposed would significantly improve component ergonomics and make design systems much more robust.
Figma Team, please, turn your eye on this. It’s the right time to finally implement this highly requested feature.
