ππ½ Did you allready experience the frustration of typing out a comment, then needing to check the name of a frame or another detail outside the comment section, only to lose their entire comment? π
Ideas π‘
- When a user begins typing a comment, the system should automatically save a draft of the comment at regular intervals (e.g., every 10 seconds).
- If the user navigates away from the comment section or the page, the draft should be preserved and restored when they return to the comment section.
- Provide a clear indication to the user that their comment is being saved as a draft (e.g., a small βSavingβ¦β indicator).
- Include an option for the user to manually save a draft of their comment.
- Ensure that the draft is retained even if the user logs out and logs back in, or if they access the project from a different device.
Thhis functionality will significantly improve user experience by preventing the loss of comments when users need to navigate away from the comment section for any reason.
